REST API does not deliver the correct coordinate value after the decimal.
1591
01-23-2012 10:27 PM
StefanP__Jung
When accessing a feature via REST API I get different results to the real coordinates. The feature is saved @ArcSDE with a resolution of 1000, but the REST API result has more numbers after the decimal. So there might be a problem of displaying the double value?
Sample SQL Statement:
SELECT sde.st_astext(g.shape) as wkt  FROM geodata g  WHERE gisid in (1234)
Result:
POLYGON  (( 818052.36380000 5742316.96420000,  ...)
When accessing the same feature class via REST API Query from ArcGIS Server i will get:
[       [        818052.3638000004,        5742316.9641999993       ], ... ]
The feature class has a correct topology but when accessing one feature via ST_GEOMETRY and a neighbour feature via REST API the topology is not correct any more.
Is this a general problem with ArcGIS Server REST API or only with ArcGIS Server for Java? Maybe it is a localization problem, any Idea?
Reference to the ArcSDE Post
Stefan
System:
- ArcGIS Server Java 10 SP 2 on Windows 2008 english
- ArcSDE 10 SP 2, using direct connect for all features @ mxd
- Oracle 11.2.0.3 on Windows 2008 german
StefanP__Jung
Esri was able to reproduce this issue:
NIM078128 REST JSON geometry query returns incorrect level of precision.
Stefan
StefanP__Jung
Stefan
