Rest API Bug - Cannot do a FIND on GlobalID
3505
05-12-2010 12:13 PM
DarrenMartin
If you have a layer that exposes GlobalID, doing a find task on that layer (all fields) or by including GlobalID will yeild no results;  Remove GlobalID from the list of fields and the find will work.
RaviNarayanan
Thank you for this posting. FIND using globalid field in the query or in the output fields should work in 10.0. Please let ESRI support know if this is still an issue.
