Question about clearing the cache ??
4478
6
06-20-2010 09:04 PM
NoureddineEl-zaatari
Hello,
i was wondering if we can clear the cache through code, on demand ??? is that possible ??
thank you
VasylMelnychuk
You may emulate POST call to rest admin.
URL: http://[server]/ArcGIS/rest/admin/login
POST parameters:
username - admin user name
password - admin password
redirect - http://[server]/ArcGIS/rest/admin/cache/clear (this will redirect to clear url automaticaly)
You may try someting like this:
using (System.Net.WebClient client = new System.Net.WebClient())
    client.Headers["Content-type"] = "application/x-www-form-urlencoded";
    client.Encoding = System.Text.Encoding.UTF8;
    var collection = new System.Collections.Specialized.NameValueCollection();
    collection.Add("username", adminUserName);
    collection.Add("password", adminPassword);
    collection.Add("redirect", http://[server]/ArcGIS/rest/admin/cache/clear);
    var response = client.UploadValues("http://[server]/ArcGIS/rest/admin/login", "POST", collection);
    // Process response
RaviNarayanan
At 10.0 REST API will support clearing the cache using tokens. Please see this link below for more details.
http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/generateadmintoken.html
vasmel,
i tried your code,, didnt clear the cache ?? any idea ?? i got no errors, response variable comes as an array of bytes
thanks
VasylMelnychuk
xnoor,
I have forgotten that WebClient is not supporting cookies (but it is required).
Override WebClient class to support cookies
        public class CookieAwareWebClient : WebClient
            private CookieContainer m_container = new CookieContainer();
            protected override WebRequest GetWebRequest(Uri address)
                WebRequest request = base.GetWebRequest(address);
                if (request is HttpWebRequest)
                    (request as HttpWebRequest).CookieContainer = m_container;
                return request;
Also you may convert response bytes to string:
            using (CookieAwareWebClient client = new CookieAwareWebClient())
                collection.Add("redirect", "http://[server]/ArcGIS/rest/admin/cache/clear");
                var response = client.UploadValues("http://[server]/ArcGIS/rest/admin/login", collection);
                MemoryStream stream = new MemoryStream(response);
                StreamReader reader = new StreamReader(stream);
                String responseString = reader.ReadToEnd();
I have tried this... it works for me...
Regards,
Vasyl Melnychuk
Ranga_Tolapi
Can any one give me the java equivalent code to achieve this.
Ranga_Tolapi
This java code works...
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.DefaultHttpClient;
private static void clearRestCache(String server, String username, String password) {
        DefaultHttpClient httpclient = new DefaultHttpClient();
        try {
         String loginUrl = "http://" + server + ":8399/arcgis/rest/admin/login";
         String cacheClearUrl = "http://" + server + ":8399/arcgis/rest/admin/cache/clear";
            HttpGet httpget = new HttpGet(loginUrl + "?username=" + username + "&password=" + password + "&redirect=" + cacheClearUrl);
            httpclient.execute(httpget);
        } catch (Exception e) {
         e.printStackTrace();
        } finally {
            httpclient.getConnectionManager().shutdown();
