Qualys 150568 Content-Based Blind SQL Injection on REST Endpoints
1466
02-18-2025 02:14 PM
BenRomlein
My organization uses Qualys to scan web applications. It picked up my REST endpoints and flagged them with a level 5 high vulnerability and now I have people in the security department telling me I need to fix it.
This is the summary of the problem: https://blog.qualys.com/product-tech/2023/02/09/blind-sql-injection-content-based-time-based-approac...
True condition payload is ‘ AND 1=1
This condition is true, so available records are returned, which is the same as if the payload was the item by itself.
False condition payload is ‘ AND 1=2
The condition is false, so no records are returned and the output is nothing or a message such as No Results Found.
Seeing the difference in results, the scanning engine draws the conclusion that there is a blind SQL injection vulnerability.
If I understand this correctly,  for it not to get flagged, I'd need the REST API to return the same result set for the true query "1=1" and the false query "1=1 AND 1=2" in the "where=" request parameter.
Firstly, am I reading this right? Secondly, is there any advice on how to either fix this, so it's no longer flagged as a vulnerability or convince the security department that this is not a vulnerability?
I'm Using ArcGIS Server 11.4.0 with standardizedQueries: "true" set and querying FeatureServices. (I've also tried turning off standardizedQueries as well, and it gives the same result)
The exact queries the scan used are:
  • False: '1=11 or 11=12'
  • True: '1=11 or 11=11'.
RandallWilliams
Hi Ben,
Happened to see this question, I don't typically follow this space.
This is expected behavior in ArcGIS. There's nothing to fix.
Users expect to be able to see all of the records in a spatial table. In a banking use case, where I'm only expected to see details related to my own bank record, this would be a problem. However, in the ArcGIS use case, the expected behavior is to see, for example, all points in a map in a given spatial envelope.
