Qlik Sense ESRI ReactJs integration
1323
06-12-2023 08:54 AM
sreekantamanuru
Hi All, i am trying to create a application Qlik Sense with ESRI using React JS application. Application showing Powered By ESRI message and maps are not loading. i tried  with Rest Api/ @ArcGIS Core/ Esri-loaders also. but same issue. Application is creating many bundles with related assets in folder. Can you please suggest me to get direction to resolve Map issue. Currently i am using Qlik Sense Desktop - 14.54.15 (with custom objects).
Sample Map load Code:
1) index.js - simple  ReactJs
import React, { useState,useRef, useEffect } from "react";
import ArcGISMap from "@arcgis/core/Map";
import MapView from "@arcgis/core/views/MapView";
import '../../index';
//import "./style.css";
//import "../../../node_modules/@arcgis/core/assets/esri/css/main.css";
import esriConfig from "@arcgis/core/config";
//import '@arcgis/core/assets/css/map.css';
//import "../../../node_modules/@arcgis/core/assets/esri/themes/light/main.css";
//import { loadModules } from "esri-loader";
esriConfig.assetsPath = "./assets";
//esriConfig.apiKey = "JyLU9y3QUHvrGg2tXwJ4di-bEE8tyrMUk68xGnzI2byEliOorHa3ZYr1cYPDy9Q1cZNOAZ2JlY3LcjEzWsBzjlTEuT6-9WNT06q_wlN6nUmOMRwpgLwFVvmuByb6OmEnRhitq6q83v0xqRJ9d9oiHg..";
//console.log(main);
export const Map = () => {
    const mapDiv = useRef(null);
    console.log("Map instance");
    //const view = useRef(null);
    useEffect(() => {
      if (mapDiv.current) {
        const map = new ArcGISMap({
          basemap: "streets-vector",
        const view = new MapView({
          map: map,
          container: mapDiv.current,
          center: [-95.7129, 37.0902],
          zoom: 3
        console.log( "props--" + map.basemap.title + view.zoom);
    return <div id="mapDiv" style={{ padding: 0, margin: 0, height: "1000px", width: "1000px" }} ref={mapDiv} />;
2) index.js - - second ReactJs added qlik.openApp
    useEffect(() => {
      const loadQlikObj = async() => {
        const config = {
          host:"localhost",
          prefix:'/',
          port:443,
          isSecure:true,
          //webIntegrationId: 'web-integration-id-here' //only needed for SaaS editions
        //appid
        //const app = await qlik.openApp('C:/Users/smanuru/Documents/Qlik/Sense/Apps/SreeTest.qvf', config);
        //var app = qlik.openApp('2abac31e-3b46-4b78-8bxf-c5cea1d2514d', config);
            map: map,
            zoom: 3
      loadQlikObj();
below errors i am getting:
