Problem in output REST: Exceeded record transfer limit.
5435
06-15-2011 08:16 AM
francescodi_vito
Hi guys,
i published a GP Service. When i run my model in REST and i go to see the uotput result, i have this message:
"Exceeded record transfer limit."
the output is a shp and the model is Synchronus
What is this error? there is a solution?
I use this GP Service in FlexViewer
Any help please?
ShawnaErnst
Hello!
Go to your geoprocessing service properties.  On the Parameters tab there is a item called "Maximum Number of Records Returned by Server:" if you have this set too low, then you'll get the Exceeded record transfer limit.
Shawna
francescodi_vito
Thanks very much
