Portal Admin Machines REST
2485
14
12-03-2020 07:00 PM
DeanHowell1
We need to be able to query the REST end point for the portal machines to determine the primary and standby machines but not sure what the syntax needs to be for accessing it outside the portal administrator.
The REST end point is https://admin.portal...../arcgis/portaladmin/machines?f=pjson  which works when I am in the portal admin but how do we add this to an external application with credentials / token?
DavidPike
MVP Frequent Contributor
did it work for you?
The token will last until it expires (in my example 60 minutes) and can be used for any query and doesn't need to be regenerated for a new query (if not expired of course).
You can also encode the token in a json request, but I get to the stage with this stuff that I'm happy if anything just works.
DeanHowell1
Thanks @DavidPike that is working, almost as it looks like we have some firewall issues 🙂
DeanHowell1
Hello @DavidPike I have been told that there is a proxy in place and that could be causing the issue of not being able to get the results I need. Do you know how to use the proxy https://cls-bx-proxy with what you have suggested above?
DavidPike
can you elaborate on the issue?
DeanHowell1
I am getting a token returned using the script but I then get a 'Forbidden 403' message. So it has been suggested to use the proxy server but not sure how to configure that into the script.
