Polyline midpoint
4800
02-05-2013 11:57 AM
Chula_VistaGIS
Using the rest api, I need to return a polyline feature and find the midpoint of the line.  It does not appear the api currently has any methods to return centroid or midpoints.
Does anyone have any thoughts on this ?
Bob
nicogis
if it isn't available via rest or api js you can: create soe (in ao use QueryPoint  for example) or gp or do it client side (see for example http://stackoverflow.com/questions/8542835/polyline-label-positioning-algorithm )
DominiqueBroux
Esri Frequent Contributor
You can also calculate the mid point at client side, see this LinearReferencing sample using the Silverlight/WPF API (midpoint is a particular case that you can get by: var midPoint = line.LinearPosition(line.Length()/2); )
