Offline map area created using REST API will not package
1050
08-31-2024 06:11 AM
Gravixx
I've been having an issue where when I create an offline area using the REST API, it will not finish packaging, but when I do it manually through the settings of the web map, packaging takes seconds. Here is the api post request:
URI uri = new URI("https://packaging.arcgis.com/arcgis/rest/services/OfflinePackaging/GPServer/CreateMapArea/submitJob");
            url = uri.toURL();
            HttpURLConnection connection = (HttpURLConnection) url.openConnection();
            connection.setRequestMethod("POST");
            connection.setRequestProperty("content-type", "application/x-www-form-urlencoded");
            connection.setRequestProperty("Host", "www.arcgis.com");
            connection.setDoOutput(true);
            String requestBody =    "f=json" +
                                    "&mapItemId=a29f7bc8938d4a0ab93fe03bc9e194c5" +
                                    "&areaType=ENVELOPE" +
                                    "&area=" +
                                        "spatialReference\":{\"latestWkid\":3857,\"wkid\":102100}," +
                                        "\"xmin\" : " + xmin + "," + // Top left point x coordinate
                                        "\"ymin\" : " + ymin + "," + // Bottom right point y coordinate
                                        "\"xmax\" : " + xmax + "," + // Bottom right point x coordinate
                                        "\"ymax\" : " + ymax + // Top left point y coordinate
                                    "&token=" + token;
 Even when the area is as little as a kilometer squared, it still does not package. Why could this be?
Thanks for reading!
AnthonyRyanEQL
Are there any differences when you look at the network traffic from your browser using the dev tool for manual creation as compared to your code above?
Gravixx
Sorry, I've realized that I posted the wrong rest api code yesterday, and i've changed it now. I also looked at the network traffic using the dev tool and I saw no difference in traffic.
