MultiPolygon via ArcGIS REST API
9446
11
04-16-2019 12:04 PM
MarkusÅfelt
Is it possible to use addFeatures with MultiPolygon geometry? I'm using JS API 4.10 and I'm trying to change the geometry to Polygon. Is this right way do it or is there another way? Example is appreciated.
Br,
Markus
MarkusÅfelt
Finally found the problem..... it was on the JS api side when I was running though array with .map.
So I changed to .flatMap() and it started to work.
Thanks your help guys.
Egge-Jan_Pollé
OK - good to hear the problem is solved 🙂
