HTMLPopup and paths returned.
1000
01-09-2013 01:15 PM
ReneRubalcava
Esri Frequent Contributor
I wasn't exactly sure to post this, as I'm not sure if it's something that needs to be configured in the MXD before publishing or I borked something on the install of my Server.
When I send the request for htmlPopup to the REST endpoint for a FeatureService, the paths to the arcgisoutput folder are pointing the server name and not the IP.
For example,
http://testserver1/arcgisoutput/ATTID_NUMBER.jpg
Instead of
http://ip.add.ress/arcgisoutput/ATTID_NUMBER.jpg
Everything else on the serve has worked just fine, all services work, I can edit FeatureServices no problem.
One thing on this box I do a bit different if it matters is I copy my mxd to this machine from a different machine that has ArcMap on it and use the Web Manager to publish it from the localhost.
Right now, I parse out the name with the base url manually to get it to work, but I'm thinking I must have done something wrong along the way and maybe there was a simple fix.
Thanks.
ReneRubalcava
