How to Verify a Valid apiKey at runTime
1454
04-22-2022 10:39 AM
RyanSutcliffe
I am finally moving our apps to use the new vector basemap services and have set up an ESRI API key to access the data.
I would like to write a check at runtime that ensures that the token supplied for my app will indeed work. The logic I'm thinking is something like:
At Build: load api key token (from environment variables)
At Runtime: do a basic check that token works (isn't expired, lacking credits, works with referrer, supports the services I want to use it against (e.g. search, basemaps) etc)
- Make an `esriRequest` to some url endpoint that returns a brief description validating token or no and what services it works against.
- If token is invalid handle accordingly, fall back to other basemaps, disable search etc.
However I don't see anything anywhere in the ESRI API documentation discussing any such process. Of course I could test trying to fetch a particular basemap tile and see if an error message comes back but I'd rather just have a lightweight explicit "verify token" endpoint not just for a basemap but for the token itself.
What I tried so far:
This'll work and fail with a bad token, but would like something a bit more descriptive:
require([
  "esri/config",
  "esri/request",
  "esri/Map",
  "esri/views/MapView",
  "esri/widgets/Search",
], function (esriConfig, esriRequest, Map, MapView, Search) {
   esriConfig.apiKey = "some-invalid-key-here";
    esriRequest(
    "https://basemaps-api.arcgis.com/arcgis/rest/services/styles/ArcGIS:Streets",
      responseType: "json",
    .then(function (response) {
      let data = response.data;
      console.log(data);
    .catch((err) => {
      console.log("whoops");
Wondering if anyone has any advice before I go bother ESRI Canada support and/or make an idea suggestion about this. I also welcome feedback as to why my above approach idea might not be a good idea or is ill-advised.
