How to POST update to a feature where it has a unique attribute instead of ObjectId?
810
08-16-2024 06:15 AM
RichT7301
Is it possible to use a where clause in an ArcGIS REST API POST to update attributes of a feature where a custom field as a unique value?
I have a field with unique values in it which I would like to use to identify which feature to update, rather than using ObjectId. The reason I don't want to use ObjectID is because that would require a preceding GET query to obtain the ObjectId, and that will slow down the overall processing, and will double the number of callouts consumed from my system's limit.
jcarlson
MVP Esteemed Contributor
You could use Calculate instead.
https://developers.arcgis.com/rest/services-reference/enterprise/calculate-feature-service-layer/
You'd have to format the post differently, but it can update any and all fields on the layer, and includes a where parameter. You could use it to update individual features, with "where=unique_field='some_value'" to restrict the calculation.
- Josh Carlson
Kendall County GIS
RichT7301
Interesting. Thank you Josh. I'll give that a try.
