How to ad a coded value to Domain/Coded values in a hosted Feature Layer using REST API?
1046
03-19-2024 08:15 AM
Labels (2)
Woodpeckerus
I have a hosted Feature Layer in AGOL with several coded values/domain values in some of the fields. I want to use REST API to add or remove a domain value from the layer.
I believe updateDefinition endpoint is the one I'm after as I've successfully updated the domains values with a payload like this:
  "fields": [
      "name": "fieldName",
      "domain": {
        "type": "codedValue",
        "name": "domainName",
        "codedValues": [
            "name": "Value 5",
            "code": "Value 5"
So with the payload above, my updated list of coded values/domains is basically just [Value 5] as this will replace the whole domain list.
Is there a way to 'append' coded value to the existing domain? My list of coded values looks like below and I just want to 'append' Value 5.
        "codedValues": [
            "name": "Value 1",
            "code": "Value 1"
            "name": "Value 2",
            "code": "Value 2"
            "name": "Value 3",
            "code": "Value 3"
            "name": "Value 4",
            "code": "Value 4"
I don't think that's possible, or am I missing something?
