How do i delete features using REST in my C# application?
1972
09-27-2017 12:58 PM
TheKenerson
Hi, I am having problems deleting all features within my feature layer using the following code. I'm guessing my mistake is in the reqstring . I am having a heck of a time trying to find examples of URL's that will delete all my features. Any suggestions?
        static Boolean DeleteAllFeaturesFromFeatureService()
            try
                string reqString = "https://services1.arcgis.com/0PfllXX1nvjR0pWI/arcgis/rest/services/SHAPEFILE/FeatureServer/0/deleteF...";
                HttpWebRequest req = WebRequest.Create(new Uri(reqString)) as HttpWebRequest;
                req.Method = "POST";
                req.ContentType = "application/json";
                // Encode the parameters as form data:
                byte[] formData = UTF8Encoding.UTF8.GetBytes(reqString);
                //req.contentLength = formData.Length;
                // Send the request:
                using (Stream post = req.GetRequestStream())
                    post.Write(formData, 0, formData.Length);
                // Pick up the response:
                string result = null;
                using (HttpWebResponse resp = req.GetResponse() as HttpWebResponse)
                    StreamReader reader =
                    new StreamReader(resp.GetResponseStream());
                    result = reader.ReadToEnd();
                    Console.WriteLine(result.ToString());
                return true;
            catch (Exception ex)
                Console.WriteLine(ex.Message);
                return false;
TheKenerson
It is pretty straightforward. I'm just new to rest. Here is a good example in case anyone seeing this is wondering
 string whereClause = "field_id>-1";
                string reqString = "https://services1.arcgis.com/0PfllXX1nvjR0pWI/arcgis/rest/services/SHAPEFILE/FeatureServer/0/deleteF...=" + whereClause;
Since all features have a field_id greater than -1, all features get deleted.
Now I need to figure out how to export a feature service as a shapefile using rest. If I find something useful, I will post it here....
TheKenerson
