Geoprocessing service with REST and Web
4076
06-10-2011 12:00 PM
JanicePoehlman
When I use the REST endpoint to access my geoprocessing service I can successfully run a tool (export, et al) on all my files.  When I use the web browser to access the same tool & geoprocessing service I get about a 50% success rate due to a time out error.
I suspect a time out setting somewhere in the JavaScript/Web interaction with AGS.  Has anyone else run into this issue as well and know where this parameter might be set?
The REST web.config file includes a <httpRuntime executionTimout="1200' />
The GP service parameters are default at 600s max time a client can use a service, 60s max time client will wait for service, 1800s max time idle instance kept running.
The files that I am processing should take just over 2 minutes of process time, based on testing and like-sized files.  All files run successfully at the REST endpoint --where is the (likely 120s) setting that I can change on the web end to get my larger files to process??
Thank you.
RaviNarayanan
Synchronous GP task are ideal for short running tasks. Since this task takes ~ 2 minutes, can you consider publishing this tool as an Asynchronous GP Service.
JanicePoehlman
Per your suggestion, Ravi, I'll create a separate GP service for this tool and set it up as asynchronous.  I'll serve it in our development environment.  Thanks, I'll report back on how it performs.
JanicePoehlman
Actually, I solved the timeout of exported large file sizes by changing the timeouts of a number of configuration files, which didn't affect application performance.  The configurations that I changed were:
web.config at REST api
timeout = 1200
NAM gateway
gateway timeout to 1200
web.config for application timeout
timeout value = 1200000
execution timeout = 1200000
LakshmananVenkatesan
We are facing similar problem.. that REST is geting timed out ..when I check RESTLOG.text , we are geting below error
og Entry : 11/8/2012 6:06:40 AM
  ERROR:Thread was being aborted. ::    at ESRI.ArcGIS.REST.GPServer.SubmitGPTaskJsonFormatter.Init()
   at ESRI.ArcGIS.REST.RequestHandler.ProcessRequest()
   at ESRI.ArcGIS.REST.RestHttpHandler.System.Web.IHttpHandler.ProcessRequest(HttpContext context)
  http://server1/ArcGIS/rest/services/CustomTools/GPServer/CustomTool/execute?dummyGeom={"geometryType":"esriGeometryPolyline","spatialReference":{"wkid":102100},"features":[{"geometry":{"spatialReference":{"wkid":102100},"paths":[[[-100,40],[-100,45]]]},"attributes":{}}]}&SurveyID=81|ALL&SellingCompanyName=OU=TEST+CO.+THREE,DC=WGDMS,DC=COM&BuyingCompanyName=OU=TEST+VERSION+1.7,DC=ABCD,DC=COM&f=json&
Please help on this
