geometry service
1660
07-12-2011 08:37 AM
shay-geo
We have a AGS installed on 2 servers.
Server 1 says after going to "http://server1/arcgis/SDK/REST/index.html?catalog.html" and under "Project Geometries (Operation)"
JSON Structures:
Syntax: {"geometryType" : "<esriGeometryPoint | esriGeometryPolyline | esriGeometryPolygon>""geometries" : [ <geometry1>, <geometry2> ]}
Server 2 says after going to "http://server2/arcgis/SDK/REST/index.html?catalog.html" and under "Project Geometries (Operation)"
JSON Structures:
Syntax: {
  "geometryType" : "<esriGeometryPoint | esriGeometryMultipoint | esriGeometryPolyline | esriGeometryPolygon | esriGeometryEnvelope>",
I am not sure, why server 2 has more geometry type supported.
Both servers have AGS 9.3 SP1 installed on it.
RaviNarayanan
The support for projecting an envelope was added in 9.3 SP1
http://resources.esri.com/help/9.3/arcgisserver/apis/rest/whatsnew.html
Do you see same Whatsnew.html doc on both machines?
Most likely one of the server is not in 9.3 SP1. You could also run the patchfinder utility to verify if 9.3 sp1 is installed.
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=66&MetaID=1457#idsp
