EXTRACT TIME IN AGOL using API
2009
07-22-2025 06:44 AM
AAlkhri
Question: Converting Timestamps from AGOL User Data to Human-Readable Dates
I'm using the following URL to extract user information from my ArcGIS Online (AGOL) account:
https://[My_AGOL_Account].arcgis.com/sharing/rest/portals/self/users?start=@Value(start)&num=100&f=json
This returns user data, including a field called `lastLogin` (or similar), which contains timestamps in Unix epoch format in milliseconds — for example: `1634238560000` or `1753130454000`.
When I paste these values into an [Epoch Converter](https://www.epochconverter.com/), they correctly translate to human-readable dates. However, when I try to convert them in **FME**, I can't get the TimeConverter** transformer to work properly. I've tried various formats and settings, but FME doesn't interpret the timestamp correctly.
**My Question:**
How can I convert these millisecond-based Unix timestamps (like `1634238560000`) into readable date/time values for the entire table ?
Tags (1)
AAlkhri
what was working with me is remove the digits , so the number will be just 10 dig 1634238560. SO THAT ACCPET TO COVERT
JoshuaBixby
MVP Esteemed Contributor
Originally seconds was the granularity of Unix time, and some time converters are still stuck in the past.  Try converting milliseconds to seconds and see if the time converter works.
AAlkhri
