Executing query task using field alias instead of field name
4461
06-30-2011 01:33 AM
martinsutka
I am not able to find the solution on how to execute query task using field alias instead of field name in the where condition.
Lets say I have a field defined like this:
SOME_FIELD (Type: esriFieldTypeString, Alias: SMF, Length: 15 )
using the where condition " SOME_FIELD = '000000000001943' " will get the result,
but using the where condition " SMF = '000000000001943' " will get the message "Unable to perform query."
Thanks.
AmayaMateos
Hello!!! Could you do it? I want do it too.
Thanks.
TanuHoque
you must use FieldName with the query. FieldAliases are not supported.
Field-aliases live either in the mxd or at the GDB stack, the underlying database is not aware of this, as a result it fails.
