Edit secured service without token
1639
05-23-2022 04:36 AM
MohamedG
Hello there.
I am developing an incident reporting mobile application that enables public users to report issues and incidents to the authorities.
The service that stores the submitted incidents is secured and references a feature class in an enterprise geodatabase.
As the app is for public user, the users can't be asked for usernames and passwords, so I store them in the application and generate a token every time a user submits a record.
Is there any way to give the app permission to edit the service without token?
Tags (3)
Raul_Jimenez
Hi @MohamedG,
I'm not very familiar with services referencing Feature Class in an Enterprise GDB, but just in case you don't know this, Hosted Feature Layers can be enabled for Feature collection (and can be limited for add, delete and update attributes only or attributes and geometry):
Probably being a reference service the options will be different...
Another "workaround" if nobody else help us here would be to create a Hosted Feature Layer and sync both services using Python, REST JS or the REST API directly. Not sure if Integromat (now called Make.com), Zapier, Power Automate or Tray.io would be able to connect to an Enterprise service.
I hope this helps
MohamedG
Thanks @Raul_Jimenez for your response.
The service I am using is on ArcGIS Enterprise not Online.
And I can't make it shared for public for security considerations.
Sorry for late response.
