Drawing Info Support for Dot Density
1164
07-25-2013 05:59 AM
JasonKnisley
I'm just curious if there are any plans in the near future for REST support for dot density symbology. Right now if I load a service with dot density symbology, the legend will show the same symbol for all categories rather than the actual unique symbols (using the Silverlight API). I haven't found any information about this in the REST forums, and the only thing I found in the Silverlight forum indicated that this was a limitation of the REST API.
SenthilSengodan
Are you still looking for dot density Renderer  ?
We have a custom flex library for dotdensity renderer at client side; it work as layer so, you can view it directly on ArcGIS map viewer.
Regards,
Senthil S
