Direction compressed geometry return rounded coordinates
1644
09-20-2011 05:48 AM
DmitryAleshkovsky
I have Route Task that return route and directions.
ArcGIS Server 9.3.1
When I compare coordinates in geometry from directions and coordinates from returned route, I found that coordinates in directions are rounded.
For example
1/ First geometry in directions (first start point)
    +1+8ml3h+6mgbr+0+0 (compressed geometry)
     x=9131121,y=7029115 (uncompressed coordinates)
2/ Route
Polyline:
Path0:[9131120,5196,7029114,5867],[9131712,0392,7028750,7598],[9131801,4032,7028661,28]...247 more...
First point have decimals.
x=9131120,5196, y=7029114,5867
any suggestions?
My goal is find the vertex number of all  stops in the route polyline
request
.../NAServer/Route/solve?stops=%7B%22features%22%3A%5B%7B%22attributes%22%3A%7B%22Name%22%3A%221%22%2C%22PointType%22%3A%22StopPoint%22%2C%22ReturnNumber%22%3A-1%2C%22NumVertex%22%3A-1%2C%22Status%22%3A%22Unknown%22%7D%2C%22geometry%22%3A%7B%22x%22%3A9131340.9466%2C%22y%22%3A7029490.0441%7D%7D%2C%7B%22attributes%22%3A%7B%22Name%22%3A%222%22%2C%22PointType%22%3A%22StopPoint%22%2C%22ReturnNumber%22%3A-1%2C%22NumVertex%22%3A-1%2C%22Status%22%3A%22Unknown%22%7D%2C%22geometry%22%3A%7B%22x%22%3A9184641.8256%2C%22y%22%3A7015380.9878%7D%7D%2C%7B%22attributes%22%3A%7B%22Name%22%3A%223%22%2C%22PointType%22%3A%22StopPoint%22%2C%22ReturnNumber%22%3A-1%2C%22NumVertex%22%3A-1%2C%22Status%22%3A%22Unknown%22%7D%2C%22geometry%22%3A%7B%22x%22%3A9209724.5922%2C%22y%22%3A6993433.567%7D%7D%5D%7D&barriers=%7B%22features%22%3A%5B%5D%7D&outSR=102100&ignoreInvalidLocations=true&accumulateAttributeNames=Minutes%2Cmeters&impedanceAttributeName=meters&restrictionAttributeNames=autos%2COneway&attributeParameterValues=&restrictUTurns=esriNFSBAllowBacktrack&useHierarchy=false&returnDirections=true&returnRoutes=true&returnStops=true&returnBarriers=false&directionsLanguage=en-US&outputLines=esriNAOutputLineTrueShape&findBestSequence=false&preserveFirstStop=true&preserveLastStop=false&useTimeWindows=false&startTime=&outputGeometryPrecision=9&outputGeometryPrecisionUnits=esriMeters&directionsTimeAttributeName=Minutes&directionsLengthUnits=esriNAUMeters&f=html
DmitryKudinov
Hi Dmitry,
You are correct - geometry which comes with Route directions is slightly generalized and this is by design.
You can match Stops with Directions geometry by comparing the Stops' ArriveTime attributes against either ETA or Time attribute on the Directions items (set returnStops=true).
Hope this helps,
Dmitry
DmitryAleshkovsky
Thank you, Dmitry!
I'll try your solution. I got this problem only on 9.3.1 server. On AGS-10 directions returned with decimals in coordinates.  Maybe this is about different locale(Russian) on server: comma( ",") as decimal separator? But I changed locale settings for SOC user with no result.
