ArcGIS Replacement for Google Static Maps
4887
7
05-26-2021 09:04 AM
DanielDormont
Hi, I am an application developer and am using ArcGIS Online for the first time and learning about the different location services such as basemaps, geocoding etc.
In my existing application, we use the Google Static Maps API   to generate static thumbnail images of specific basemaps with certain custom overlays on top of them. Basically, it's a URL where you specify the image size, bounds, map "type" (basically a basemap) and some minimal data about the custom marker, polygon etc that you want drawn on it, and some kind of authentication. The URL itself returns an image that you can embed directly in a web page or other document. There is no need to parse the response.
I am looking for something similar in the ArcGIS world and having a hard time finding it. Some searches have turned up results looking for "downloading" or "exporting" a map, but I don't think that's what I want, or if it is, I am looking for guidance on how that would translate into the "static maps" requirement that I have.
Thanks
PS. It looks like the search turned up a few related posts, but I am not running ArcGIS server myself. I was looking for a service my application could consume from the cloud similar to what Google, Mapbox etc. provide.
GavinRehkemper
EDIT: As of 2026, check out ArcGIS Static Maps service.
Previous answer:
One way to do this is to use the "Export Web Map Task". It can output images (PNGs, JPGs, etc) as well as PDFs based on a configuration of layers (Web_Map_as_JSON) that you pass in as a parameter.
Documentation: https://developers.arcgis.com/rest/services-reference/enterprise/export-web-map-task.htm
Depending on your requirements, you can send this request via GET or POST. See this endpoint form for help on constructing the request: https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%...
Demo: I cannot copy/paste the full URL here because it's too long, so you can go here and copy/paste this URL into your browser. It will send back a JSON response that contains a link to the image. https://www.arcgis.com/sharing/content/items/fe52496307ff4defa1fb8f9c55533f3d/resources/get-image-ur...
GavinRehkemper
Previous answer:
DanielDormont
Thanks, that is along the lines of what I'm looking for. I'm not yet familiar with the Export Web Map Task but I'll see what I can find.
luckachi
@DanielDormont Were you able to accomplish this? I am trying to find a suitable replacement for the Google maps api where I just need a static map and then pass coordinates via the URL to place a marker. No interaction, just simple and I haven't really found a good example
DanielDormont
Hi, @luckachi unfortunately no I was not able to find anything in the ArcGIS platform that could do this for me. The Export Web Map Task is along the right lines, but it doesn't allow you to construct a simple URL that will return the image in the way that Google or Mapbox offer.
luckachi
@DanielDormont Ugh, that is disappointing. We have been having some issues with Google API for the last few months so we were hoping ESRI offered something similar. Thank you for the quick reply!
TrevorH_OPE
Fear not fellow static mappers, there is a new API coming 😄
https://developers.arcgis.com/rest/static-maps/
DanielDormont
Thank you for the heads up! I very eagerly signed up for the beta and started playing around. Unfortunately, it has some gaps that will be showstoppers for me (but may not be for everyone, so don't let me rain on your parade too much :😀)
if you want to use a custom symbol, the request has to be a POST, not GET
- if you want to use a custom symbol, it has to be a SVG, not PNG
- it don't support polygons at all, from what I can tell
- instead of just plopping a copyright inside the image itself like Google and Mapbox do, you have to call a separate API to obtain the attribution text and show it somewhere near but not exactly on the image.
Hopefully these can get resolved? 🤞
