Is it possible access the pooling properties for an Map/Feature Service via the REST API? I can see that it's possible to get/set the min/max instances but I can't see any properties that indicate if it is a shared or dedicated instance.
Solved! Go to Solution.
Also the provider will be set to “DMaps” for shared pool services.
Yes you can but it’s on the admin api.
Thanks Trevor, I'll take a look.
Thanks Trevor but I believe that is just a setting for the ArcGIS Server itself where it will default to the shared instance pool for new services. I need to get the property for each individual service.
Oh yes sorry that was the wrong link. Should be this one.
https://developers.arcgis.com/rest/enterprise-administration/server/editservice.htm
I’ve used this to bulk update the minimum instances for each service in the past.
Yeah that's the only documentation I can find and there's no reference to whether the service is set to use shared or dedicated instances, only min/max instances.
That’s what the provider setting indicates.
If it’s DMaps it’s shared pool. If it’s ArcObjects it’s dedicated.
So this is a dedicated service
This is a shared pool service - notice the instances are set to zero
What version of AGS is that from? I'm seeing min/max of 1/2 for shared and no provider property.
