I was looking for a solution to this and eventually just wrote a script to do it. Just make a temp directory, and run this in the python console, and have fun.
############################################# # Description: Updates the description of each layer in # the current mxd. # # Useful if the metadata changes, and you want the metadata # to be reflected in the mxd layer description ############################################# import arcpy from xml.etree.ElementTree import ElementTree #set local variables dir = arcpy.GetInstallInfo("desktop")["InstallDir"] translator = dir + "Metadata/Translator/ESRI_ISO2ISO19139.xml" mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] temp_path = "C:/temp" for layer in arcpy.mapping.ListLayers(mxd, "*", df): if not layer.isGroupLayer: description_text = "" path = temp_path + '/' + layer.datasetName + '.xml' print path arcpy.ExportMetadata_conversion(layer.dataSource, translator, path) dom = xml.dom.minidom.parse(path) fields = ('abstract', 'purpose', 'credit') for field in fields: tags = dom.getElementsByTagName(field) print str( len(tags) ) + ' | ' + str( tags ) if len(tags): tag_string = tags[0].getElementsByTagName('gco:CharacterString')[0].childNodes[0].nodeValue description_text = description_text + "\n\n" + field.capitalize() + ":\n" + tag_string print description_text layer.description = description_text if field == 'credit': layer.credit = tag_string
FYI, this script has been updated to be a little more robust.
esri-python-tools/UpdateMXDMetadata.py at master · roemhildtg/esri-python-tools · GitHub
