Hey all,
I need a GeoJSON URL of this layer with a query for the boundary of Winston-Salem only.
There is a GeoJSON URL for the entire feature service available (under API resources on the right) but I'm unsure as to how to use the "query?outFields=" in the URL to bring back Winston-Salem specifically.
Can anyone help?
Thanks!
Solved! Go to Solution.
If you look at the REST API page for the Corporate Limits layer (ID:0) (Layer: Corporate Limits (ID:0) (arcgis.com)), you will see MUNICIPALITY uses coded values. For Winston-Salem, that would be 'WS'. So you want a where clause of:
MUNICIPALITY='WS'
MUNICIPALITY='WS'
Thanks Josh. I tried the URL below but it didn't work. I'm sure the formatting after "where=" is wrong. What can I do to correct it?
Can you elaborate on "didn't work?" I just clicked on the hyperlink, and it opened a window with results I would expect.
I was testing the link by adding it to a web map. Got a message that said "unable to display filter" but I think it's because it's a GeoJSON URL. The feature showed up fine in the map. I think it's working fine, that just confused me. Thank you for your help!
