generate a token with arcgis server url
3201
11-02-2020 11:41 AM
Pa_Lotus
in 10.3 server some of my apps configured to get token from httpGet
with these sample format url, i used to generate token by passing values,  https://abc.123.com/webAdapterName/tokens/generateToken
recently we upgraded to 10.8 enterprise portal architecture
https://Newabc.123.com/webAdapterName/tokens/generateToken
the message i get is "HTTP GET is disabled"
from this page Enable token acquisition through an HTTP GET request—ArcGIS Server | Documentation for ArcGIS Enterp... , i added " "allowHttpGet": "true"" and updated the token.
after that, i get result as below
Any suggestions please, for generating tokens, with the rest api, am trying to use it in c#
Thanks
RandyBurton
For security reasons, you would not want the username and password appended to the URL and sent unsecured as is the case for a get request.  Look in your documentation on how to generate a post request.
For reference: HTTP Methods GET vs POST
Br1an_Peters
did you ever solve this?
