Export Map Image - Map Lines renders jagged/pixelated
4165
11-18-2010 10:04 AM
PieterCoetzer
Hi Guys,
I have a service running displaying the road lines. In ArcMap, the lines display perfectly, but after I have published the service as a Dynamic service, the lines renders all jagged and in some cases pixelated.
I also make use of the ExportMap function to generate a static map image, but in most cases the map renders such jagged lines (at any DPI).
How would I go about rendering smooth lines in a AGS service?
Thanks in advance,
Pieter
RaviNarayanan
Pieter,
you can try publishing a msd document with anti-aliasing setting enabled in the publishers arcgis server options.
Please see below a couple of help documents on this topic:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00sq00000028000000.htm
See section anti-aliasing map techniques in this following topic:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Publishing_map_services/00sq0000001800...
