ArcGIS Server REST Accent Insensitive!
2820
6
10-06-2010 11:34 AM
YgorThomaz
How can i make a consult in my ArcGIS REST Services and become the querys Accent Insensitive.
Example:
Where = "COLUMN like âRCGÃs"
return of the query:
arcgis
ArcgIS
ârcgÃs
Thank's!
ChrisSmith
I assume you can set this up when you specify your database collation, since the rest api runs valid sql statements then I assume it will be reliant on the database to handle the accent insensitive queries.
Maybe you can pass the following in the rest where clause...
http://stackoverflow.com/questions/507504/accent-and-case-insensitive-collate-equivalent-in-oracle
regards
chris
YgorThomaz
Chris,
In the Oracle i don't have problem for do it. In our case it's used consults(queries) REST and not PL/SQL Oracle statement.
Remember, all consults(queries) in the ArcGIS Server are made for REST services.
So, i need of a statement or config(ArcGIS Server or application) for searching Accent Insensitive in services REST.
Thanks! (:
ChrisSmith
Hi
I dont quite understand what you mean by 'consults', can you give a bit more info
regards
chris
ChrisSmith
which also suggest I might not be the right person to answer your question 😄
regards
chris
YgorThomaz
consults = queries
ChrisSmith
ah yes you were quite clear in the previous post, would have helped if I actually read it properly  - LOL
the Rest api suggests any legal SQL statement is valid in the where clause for a Rest Query - I assume that excludes adding an NLSSORT directly in the where clause?
When you run the PL/SQL statement do you specify anything in your query to make it accent insensitive or has this been setup in the init parameters file
been a couple of years since I last used Oracle so will bow out now and leave it to someone with a bit more knowledge and access to an actual Oracle instance 🙂
good luck!
chris
