QuickCapture won't run tracks in background, crashes
3334
10
01-06-2023 03:20 PM
RemyHenderson
Hi esri community,
I am looking to use QuickCapture as a solution to record tracks and points at the same time (which I've learned Field Maps can't do). Our field team operates only in out-of-service areas, so cellular or wifi connection is never available. I've got QuickCapture designed in a way that works really well for us, but unfortunately the app will not record tracks when the app is not actively being used. After a few seconds to minutes of running in the background, the app crashes and takes me back to the orange highway loading screen when I re-open it, where I then have to re-open my project. It also turns off my tracking function, so no tracks are recorded during this time, and tracking is off until you turn it back on. Seems like I'm having a similar problem as this person, but when I re-open the app it doesn't have tracking on. Any suggestions on how to fix this?
Also worth noting, I am able to stream tracks in the background with field maps with no issues, and field maps and quick capture have the same permissions settings on my device. This makes me think the issue is not related to a setting on my device.
StephenRead
Another note in case helpful; QuickCapture needs to be configured to keep running in the background rather than going to sleep or closing. Have a look in your device settings. On my Samsung it is the App info settings where I turn off 'Manage app if unsused' and also the App permissions so that Location is allowed all the time.
I hope that this helps.
