I'm looking for a way to take a multiple photos in quick capture and assign the same attribute table data to the group.
Hi @SAMHAYES1 check out this blog about multiple photos data collection with QuickCapture https://www.esri.com/arcgis-blog/products/quickcapture/field-mobility/whats-new-in-arcgis-quickcaptu...
Hi @SAMHAYES1,
We are currently working on the support for multiple photos in QuickCapture, it will be available in the upcoming release if everything goes well. Can you be more specific on what attributes to be stored in the captured records/photos?
Mandy
Hi! is there any advancement on this?
Hey @Pegah_Nouri multiple photos data collection is already supported in QuickCapture 1.10, which is the August 2021 release. Check out this blog https://www.esri.com/arcgis-blog/products/quickcapture/field-mobility/whats-new-in-arcgis-quickcaptu...
Thanks Mandy.
The created data fields in the feature layer - is it possible to have multiple photos to row of data or multiple photos but with the same data copied across multiple rows?
