Layer I need does not show in creating Quick Capture project
1699
10-13-2023 01:02 PM
MarkDoehnert
I am trying to create my first project to use Quick Capture, where I am trying to use my smartphone and the QuickCapture app to support a conditions assessment of sidewalks in my neighborhood.
However, the map I want to use does not show up in the "Select feature layers"
I have a map with two  layers, the addresses in my neighborhood and a state sidewalks layer, on  a basemap of aerials.
Neither the map nor either of the two layers show up in the "Select feature layers," and I am not sure what to do next.
JohnathanHasthorpe
Hi. The starting point of a QuickCapture project is not a map, it is a feature layer.
You will need to select the feature layers ( addresses and state sidewalks) you want to send records to.
Once you create you project, you can then select your map as the project map in project settings.
This means that the user will be able to view the map in the mobile application.
https://doc.arcgis.com/en/quickcapture/help/editproject.htm
JohnathanHasthorpe
