Could we take the photo after filling out the form ? (by default, photo is taken first).
And could we skip adding photos in some cases? (keep photo functionality active but photo could not be required).
Thank you in advance,
Hi Joanne
You can't currently take the photo after entering a user input. However, we can add an enhancement request for this.
You can allow the user to skip a photo if you make the photo optional. To do this, in the designer you need to reduce the minimum number of photos to be less than the maximum:
I hope this helps
John
Hi Joanne
I hope this helps
John
I would love this as an enhancement.
Hi John,
Perfect, I didn't know about this optional mode for pictures...!
Many thanks!
Joanne
