Button Debounce
811
05-08-2025 07:34 AM
StephenEJohnson
Using app version 1.22.6 on an iPhone and iPad.
I had set up a QuickCapture app to send an email when a button is pressed (through MS Power Apps). The problem is not with Power Apps. The issue is that when the button is pressed, several identical events (up to 7) are saved to the related feature layer. In hardwired electronics what we would call a key debounce issue. I have seen community questions referencing a fix to this in a version of QuickCapture but I am still seeing an issue. This issue is repeatable on multiple devices. The reason I say this is not a Power Apps issue is that the multiple identical events are generated and saved in the feature layer. Power apps just monitors for changes in the feature layer and dutifully takes an action for the new records that are added to the table. I could, and have tried, to set up Power Apps to filter the events but this is somewhat complex and is a workaround for a QuickCapture issue. The automation sends emails to multiple recipients so allowing this to continue is not an option. I had to disable this button temporarily until I get a fix.
JohnathanHasthorpe
The QuickCapture mobile application will make a request to the the webhook URL (passing through the feature payload) each time a feature is uploaded. It will only ever send one request per feature and it does not ever retry.
Is it possible that it look a few attempts for the feature to be uploaded - i.e. were you sending in an area of poor network coverage?
Also, can you explain what your webhook scenario is doing? Is it writing features to a feature service?
