Edge matching country borders
2957
7
07-16-2021 09:50 AM
tonybestpro
This question has been posted in another section. I was recommended to use "Fill gaps", but none of ESRI customer services, our production license, and ArcGIS pro trial license has the license for "fill gaps", can someone help test using "fill gaps". Thanks.
Bo_King
Esri Alum
Hi @tonybestpro
The Fill Gaps tool requires an Advanced license of Production Mapping.  You can check your licensing here:  ArcGIS Pro > Settings > Licensing
To the best of my knowledge, the free 21 day trial of ArcGIS Pro does not include the Production Mapping extension.  For more info on the ArcGIS Pro Free Trial, or testing ArcGIS Production Mapping, please contact Esri Sales here:  https://www.esri.com/en-us/arcgis/products/arcgis-pro/trial
DanPatterson
MVP Esteemed Contributor
this fill gaps?
Fill Gaps (Topographic Production)—ArcGIS Pro | Documentation
... sort of retired...
tonybestpro
I think so. I was told it is under the production mapping extension of ArcGIS.
DanPatterson
That it is...
tonybestpro
Yes, but none of ESRI customer services (we were on the phone for ~ two hours), our production license, and ArcGIS pro trial license have the license to "fill gaps". I cannot use it. I like to see if it works before buying it.
DavidPike
MVP Notable Contributor
Possibly Integrate (Data Management)—ArcGIS Pro | Documentation but beware all of the caveats with using the tool e.g. make a copy of your data sources as this modifies them in-place.
tonybestpro
I tested Integrate too. It did not work.
Bo_King
Esri Alum
Hi @tonybestpro
