VB.NET Layer set SetMaxScale / SetMinScale
1944
04-06-2024 12:05 PM
SigurdurGesr
Hi
I am try to set Layer MaxScale it look like nothing happened
        Dim layerName As String = Layer_HR
        Dim HRLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType(Of BasicFeatureLayer)().FirstOrDefault(Function(l) l.Name.Equals(layerName))
        HRLayer.SetMaxScale(501)
Thanks
Sigster
GKmieliauskas
At first, SetMaxScale must be called on MCT thread inside QueuedTask.Run.
After setting new values open layer properties and check is values are specified (general tab).
Max value must be less then min value:
I have tried vb sample from community samples with values:
                    multiPointLayer.SetMaxScale(1000000)
                    multiPointLayer.SetMinScale(5000000)
And it works as expected. It could be that your values are to small or not in expected range
GKmieliauskas
SigurdurGesr
What is MCT thread ?
        Dim layerName As String = Layer_NR
        Dim NRLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType(Of BasicFeatureLayer)().FirstOrDefault(Function(l) l.Name.Equals(layerName))
        QueuedTask.Run(Function()
                           NRLayer.SetMaxScale(1000000)
                           NRLayer.SetMinScale(5000000)
                       End Function)
GKmieliauskas
MCT means that you must call method inside QueuedTask.Run. Like in your second code sample
SigurdurGesr
Thanks GKmieliauskas
