Using Inspector to modify attribute field in multiple features
2043
02-26-2023 06:19 AM
Zoltan_Szecsei
I am struggling to get this snippet to work:
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Editing#edit-operation-modify-multiple-featu...
// at Heading: Edit Operation Modify multiple features
Problem #1 is:
My code below works, loads 421 OIDs but does not execute because modifyFeatures.IsEmpty is TRUE.
The existing date attribute is shown as day-month-year when I look at the attribute table in ArcPro 3.0.2
Problem #2 is:
I am currently selecting on OID to debug this code, but I need to select features with a specific DATE_LASD.
The following WhereClause fails with 'An invalid SQL statement was used.'
(I have tried '-' instead of '/' and also MM-DD-YYYY)
//selq.WhereClause = "DATE_LASD = '20/04/2022'"; // This format is what is shown in Attribute Table
Can anyone spot my deliberate error?
Thank in advance,
Zoltan
        public static void setDateLASD()
            //from:  https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Editing#edit-operation-modify-multiple-features
            // First deactivate OnRowChanged
            var selq = new QueryFilter();
            //selq.WhereClause = "DATE_LASD = '20/04/2022'";  // This is s what is shown in Attribute Table
            selq.WhereClause = "OBJECTID > 7";
            IEnumerable<FeatureLayer> layers = MapView.Active.Map.GetLayersAsFlattenedList().Where(
                layer => layer is FeatureLayer).Select(x => (FeatureLayer)x);
            foreach (var dset in layers)
                if ((dset.Name.EndsWith("_Point")) ||
                    (dset.Name.EndsWith("_Line")) ||
                    (dset.Name.EndsWith("_Polygon")))
                    QueuedTask.Run(() =>
                        var oidSet = new List<long>();
                        using (var selset = dset.Search(selq))
                            while (selset.MoveNext())
                                using (var record = selset.Current)
                                    oidSet.Add(record.GetObjectID());
                        //create and execute the edit operation
                        var modifyFeatures = new EditOperation();
                        modifyFeatures.Name = "Modify LASD";
                        modifyFeatures.ShowProgressor = true;
                        var multipleFeaturesInsp = new Inspector();
                        multipleFeaturesInsp.AllowEditing = true;
                        multipleFeaturesInsp.Load(dset, oidSet);
                        multipleFeaturesInsp["DATE_LASD"] = "21/08/2022";
                        modifyFeatures.Modify(multipleFeaturesInsp);
                        if (!modifyFeatures.IsEmpty)
                            var result = modifyFeatures.ExecuteAsync(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
                // Now reactivate OnRowChanged
GKmieliauskas
Problem 1:
I have reported case to esri support about that in November 2022. Case number #03196489
Just ignore IsEmpty value for now, or use your workaround to count for changes.
Problem 2:
Date is not simple string value. Let's try like this:
selq.WhereClause = "DATE_LASD = date '2022-04-20 00:00:00'";
More info here:
SQL reference for query expressions used in ArcGIS—ArcGIS Pro | Documentation
GKmieliauskas
Problem 1:
Problem 2:
More info here:
Zoltan_Szecsei
Both worked.
Many thanks
Regards,
Zoltan
