Use Arcade with Pro SDK
1906
04-03-2018 11:48 PM
TakahiroKAMIYA
Is there an example of sample code and usage in Pro SDK?
Is it possible to change the renderer using Arcade?
Examples of this profile in context
https://developers.arcgis.com/arcade/guide/profiles/
Tags (1)
UmaHarano
The SDK Documentation will soon include a few snippets that modify the renderer and create labeling expressions using Arcade.  Here are a couple of snippets:
Modify renderer using Arcade
var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.ShapeType == esriGeometryType.esriGeometryPolygon);
if (lyr == null) return;
QueuedTask.Run(() => {
    // GetRenderer from Layer (assumes it is a unique value renderer)
    var uvRenderer = lyr.GetRenderer() as CIMUniqueValueRenderer;
    if (uvRenderer == null) return;
    //layer has STATE_NAME field
    //community sample Data\Admin\AdminSample.aprx
    string expression = "if ($view.scale > 21000000) { return $feature.STATE_NAME } else { return 'All' }";
    CIMExpressionInfo updatedExpressionInfo = new CIMExpressionInfo
        Expression = expression,
        Title = "Custom" // can be any string used for UI purpose.
    //set the renderer's expression
    uvRenderer.ValueExpressionInfo = updatedExpressionInfo;
    //SetRenderer on Layer
    lyr.SetRenderer(uvRenderer);
Modify label expression using Arcade
    //Get the layer's definition
    var lyrDefn = lyr.GetDefinition() as CIMFeatureLayer;
    if (lyrDefn == null) return;
    //Get the label classes - we need the first one
    var listLabelClasses = lyrDefn.LabelClasses.ToList();
    var theLabelClass = listLabelClasses.FirstOrDefault();
    //set the label class Expression to use the Arcade expression
    theLabelClass.Expression = "return $feature.STATE_NAME + TextFormatting.NewLine + $feature.POP2000;";
    //Set the label definition back to the layer.
    lyr.SetDefinition(lyrDefn);
Thanks
Uma
UmaHarano
Thanks
Uma
TakahiroKAMIYA
Thanks Uma,
I will check about operation.
Regards,
Takahiro Kamiya
