Unable to create a new row in a featureclass in Enterprise gdb
1712
09-21-2023 12:35 PM
ViktorSafar
I am trying to save a new feature into a SQL Server gdb table. The process succeeds (editOperation.ExecuteAsync returns true) and I even get the new feature's globalID. But I cannot see the new feature in the table using SQL Server Management Studio (querying by globalID).
(I call Project.Current.SaveEditsAsync() after the code below.)
I have been following this https://github.com/Esri/arcgis-pro-sdk/blob/e79fbb738b32dd178c089a6b321e2098f8c9c069/Examples/Geodat...
This is my code
using var gdb = new Geodatabase(SMARTConnectionsProvider.Connection);
using FeatureClass fc = gdb.OpenDataset<FeatureClass>(SMARTConnectionsProvider.SOMETABLE.TableName);
var editOperation = new EditOperation();
editOperation.Callback(context =>
	using var rowBuffer = fc.CreateRowBuffer();
	rowBuffer[SMARTConnectionsProvider.SOMETABLE.Fields.RANGEID] = rangeId;
	rowBuffer[SMARTConnectionsProvider.SOMETABLE.Fields.SID] = smalId;
	rowBuffer[SMARTConnectionsProvider.SOMETABLE.Fields.SHAPE] = geometry;
	var newFeature = fc.CreateRow(rowBuffer);
	Log.Information($"GLOBALID {newFeature.GetGlobalID()}");
}, fc);
return await editOperation.ExecuteAsync();
Wolf
by Esri Regular Contributor
Here are a few things to consider:
- Did Project.Current.SaveEditsAsync() return true?
- Do you see the newly added data in the table view in ArcGIS Pro ?
- Is your GeoDatabase versioned?  If so that might explain why you don't see the data using SQL Server.
Wolf
ViktorSafar
Yes
Just opened it now, yes, my data is the table when viewed via ArcGIS Pro. The data is not there when I query the same instance/table with the same connection detail via SSMS
I don't think so, or at least Pro is showing only the default version.
ViktorSafar
Found out the feature class is indeed versioned and my data are in SOMETABLE_evw view.
in Pro - right click on the feature class - Properties - and there is says Versioning: Versioned
https://community.esri.com/t5/arcgis-enterprise-questions/can-t-see-new-data-in-databases-in-sql-ser...
