Typo in LicensingBackstageViewModel? WAS: Typo hide and seek. Where to go when Visual Studio fails you?
915
02-14-2023 05:00 PM
RogerAsbury
Edited the title as this appears to be a typo in the SDK LicensingBackstageViewModel class.
I was handed a stub of a project from a third party. Basically, the start of a project with little functionality. One of the first things I noticed is that when run in Debug mode from VS2022, it pops up a little licensing checkbox on the Licensing settings page of ArcGIS Pro, as seen below:
 Clicking the box under Enable does the obvious, allow the addin to be used. However, it wasn't saving that setting between session, so I started looking in error messages to see what I could find and came across this:
System.Windows.Data Error: 40 : BindingExpression path error: 'ShowWorkstatoin' property not found on 'object' ''LicensingBackstageViewModel' (HashCode=28807604)'. BindingExpression:Path=ShowWorkstatoin; DataItem='LicensingBackstageViewModel' (HashCode=28807604); target element is 'Grid' (Name=''); target property is 'Visibility' (type 'Visibility')
There's a typo in there: "ShowWorkstatoin". I've searched the project multiple times with VS's search feature. I've used Windows search to search within the content of items in the folder of the project to no avail. I even set it upon my entire C:\ drive searching for the typo and everything comes up empty. I even did the search for LicensingBackstageViewModel and come up empty.
Is there a better way to be searching for this? Am I missing a handy VS feature to find text in a project that the search on the Solution Explorer is missing?
Roger Asbury
Analyst/Programmer - Fairbanks North Star Borough
CharlesMacleod
That looks like a bug in Pro. It seems the checkbox on the licensing tab cannot find the property it is bound too - presumably because of a typo. I will check with the development team. Is this 3.0?
RogerAsbury
Yes, this is 3.0. Thanks much!
Roger Asbury
CharlesMacleod
this will be fixed in 3.2. we will get the fix into next available patch for 3.0
