The tooltip heading in the button palette doesn't update when I change to a different tool. For example,
I have 3 different buttons with their own caption and tooltips.
Below is sample code for reference:
<SPAN class="operator token"><</SPAN>buttonPalette id<SPAN class="operator token">=</SPAN><SPAN class="string token">"CustomPalette"</SPAN> caption<SPAN class="operator token">=</SPAN><SPAN class="string token">"Custom buttons"</SPAN> extendedCaption<SPAN class="operator token">=</SPAN><SPAN class="string token">"Open custom buttons palette"</SPAN> dropDown<SPAN class="operator token">=</SPAN><SPAN class="string token">"false"</SPAN> menuStyle<SPAN class="operator token">=</SPAN><SPAN class="string token">"true"</SPAN> showItemCaption<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"A"</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"B"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button refID<SPAN class="operator token">=</SPAN><SPAN class="string token">"C"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>buttonPalette<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"A"</SPAN> caption<SPAN class="operator token">=</SPAN><SPAN class="string token">"Button A"</SPAN> <SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>tooltip heading<SPAN class="operator token">=</SPAN><SPAN class="string token">"Button A"</SPAN><SPAN class="operator token">></SPAN>
Tooltip <SPAN class="keyword token">for</SPAN> Button A<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN>disabledText <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>tooltip<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>content <SPAN class="keyword token">group</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"Custom"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"B"</SPAN> caption<SPAN class="operator token">=</SPAN><SPAN class="string token">"Button B"</SPAN> <SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>tooltip heading<SPAN class="operator token">=</SPAN><SPAN class="string token">"Button B"</SPAN><SPAN class="operator token">></SPAN>
Tooltip <SPAN class="keyword token">for</SPAN> Button B<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN>disabledText <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>tooltip<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Initially, when I scroll over button A, it displays the correct tooltip heading ("Button A") and tooltip("Tooltip for Button A").
But, when I switch to tool B by clicking on button B in the palette, the tooltip gets updated accordingly (Tooltip for Button B") but the tooltip heading still reads "Button A" instead of "Button B". Is this an existing bug in the SDK?
I tried changing all options in the buttonPalette control. Changed showItemStyle to 0,1,true, false. No luck.
Any help would be greatly appreciated. Thank you!
