Setting Spatial Reference to a newly created map
1750
04-25-2020 03:54 AM
Vidar
This is a basic question - but seem to be having a hard time getting an answer from the online help.
I want to set a coordinate system when I make a new map pane. You cannot seem to specify when you use the MapFactory and once the map is made the SpatialReference property is readonly.
Could someone point me in the right direction to change or set the spatial ref of a map.
UmaHarano
The method is on the Map class.  SetSpatialReference method.
Thanks
Uma
UmaHarano
Thanks
Uma
Vidar
I'm embarrassed how I missed that!
by Anonymous User
Not applicable
Sample:
var mv = MapView.Active;
Map m = mv.Map;
var WkidValue = 4326;
m.SetSpatialReference(SpatialReferenceBuilder.CreateSpatialReference(WkidValue));
