Setting HtmlPopupFormat to a layer
834
11-20-2020 09:16 AM
WilliamYu
I was wondering if there is a way to access the HTMLPopupFormat property of a layer in Pro as a user. I see that the property gets added when using the KML to Layer geoprocessing tool. Is there a way to modify it without using code?
Thanks
Wolf
by Esri Regular Contributor
As far as I know you can't update this from the UI.  These are the only options I know of: https://pro.arcgis.com/en/pro-app/help/mapping/navigation/configure-pop-ups.htm
However, for Pro UI questions you should post your question here to make sure:
 https://community.esri.com/t5/arcgis-pro-questions/bd-p/arcgis-pro-questions
