Setting Alias on MapProjectItem does not retain
1203
12-01-2022 07:38 AM
LynneB
I'm trying to set the Alias on a MapProjectItem.  The code works and the value is set if I repeat the code in the same Pro session but once I exit Pro and go back in, the Alias is back to null.
                IEnumerable<MapProjectItem> mapItems = Project.Current.GetItems<MapProjectItem>();
                foreach (MapProjectItem mapItem in mapItems)
                    mapItem.Alias = "DA Test Alias";
I'm using Pro 3.0
Wolf
by Esri Regular Contributor
I was able to duplicate the issue with the Alias property not retaining its value between sessions even when i explicitly save the project.  I reported this as an issue to the Framework dev team.  Thanks for reporting this issue.
GKmieliauskas
I think you need to save project:
await Project.Current.SaveAsync();
Wolf
