SchemaBuilder error with enterprise geodatabase
187
07-03-2026 03:14 PM
Pierre-YvesCURTINOT
I wrote code that adds a field to a feature class using SchemaBuilder. It works correctly with a file geodatabase, but not with an enterprise geodatabase hosted on PostgreSQL. In that case, an error message is returned stating: "The Fields collection contained multiple geometry fields. (st_perimeter(shape)".
The error occurs regardless of the geometry storage mode (PostGIS or ST_Geometry).
    var featureClass = featureLayer.GetFeatureClass();
    using (var geodatabase = featureClass.GetDatastore() as Geodatabase)
        var fcDefinition = featureClass.GetDefinition();
        var fcDescription = new FeatureClassDescription(fcDefinition);
        var fieldDescription = ArcGIS.Core.Data.DDL.FieldDescription.CreateStringField("NEW_FIELD", 50);
        var newFcDescription = new List<ArcGIS.Core.Data.DDL.FieldDescription>(fcDescription.FieldDescriptions);
        newFcDescription.Add(fieldDescription);
        FeatureClassDescription newDesc = new FeatureClassDescription(fcDescription.Name, newFcDescription, fcDescription.ShapeDescription);
        var schemaBuilder = new SchemaBuilder(geodatabase);
        schemaBuilder.Modify(newDesc);
        bool res = schemaBuilder.Build();
        if (res)
            MessageBox.Show("Field added");
        else
            MessageBox.Show(schemaBuilder.ErrorMessages.First().ToString());
Is this a known issue or an expected behavior? Is there a different way of adding a field with the SDK when working with an enterprise geodatabase?
Thanks for your help.
Aashis
by Esri Contributor
Which version of ArcGIS Pro are you using? I'd like to see if I can replicate the issue on our end.
Pierre-YvesCURTINOT
ArcGIS Pro version: 3.6.4   PostgreSQL version: 13.8
But I wonder if the problem might simply stem from a compatibility issue with the st_geometry library.
