Rollback insert and delete from GDB's feature class to Oracle feature's SDE
1696
04-01-2024 04:32 AM
SumitMishra_016
Hi All,
I am using the following to delete the features in target SDE:
EditOperation editOperation = new EditOperation();
editOperation.Callback(context =>
    ArcGIS.Core.Data.QueryFilter openCutFilter = new ArcGIS.Core.Data.QueryFilter { WhereClause = "field = 'something'" };
    using (RowCursor rowCursor = featureClass.Search(openCutFilter, false))
        while (rowCursor.MoveNext())
            using (Row row = rowCursor.Current)
                // In order to update the Map and/or the attribute table. Has to be called before the delete.
                context.Invalidate(row);
                row.Delete();
}, featureClass);
After deleting I want to insert all the data from GDB to SDE. How to achieve this?
SumitMishra_016
@Aashis Thanks for the reply. I am to insert now by following code :
foreach (var sourceField in sourceFeature.GetFields())
    if (sourceField.Name == sourceFeatureClass.GetDefinition().GetObjectIDField())
        continue;
    // Find the corresponding field in the target feature class
    int targetFieldIndex = targetFeatureDefinition.FindField(sourceField.Name);
    // If the field exists in the target feature class
    if (targetFieldIndex >= 0)
        // Get the value of the field from the source feature
        var value = sourceFeature[sourceField.Name];
        //targetRowBuffer[targetFeatureDefinition.GetShapeField()] = featureGeometry;
        // Set the value in the target row buffer
        targetRowBuffer_i[targetFieldIndex] = value;
Aashis
by Esri Contributor
For data insert, have you looked into the insert cursor?
For further details, please refer to the conceptual doc.
SumitMishra_016
Hi @Aashis  thanks for the reply,
EditOperation insertOperation = new EditOperation();
insertOperation.Callback(context =>
    using (Geodatabase gdb = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("source.gdb"))))
            // Open the source feature class
            using (Table sourceFeatureClass = gdb.OpenDataset<Table>("fcname"))
                using (InsertCursor insertCursor = featureClass.CreateInsertCursor())
                    // Iterate through the rows in the source feature class
                    using (RowCursor sourceCursor = sourceFeatureClass.Search())
                        while (sourceCursor.MoveNext())
                            using (Row sourceRow = sourceCursor.Current)
                                Feature feat = (Feature)sourceCursor.Current;
                                // Create a new row buffer for the target feature class
                                using (RowBuffer targetRowBuffer = featureClass.CreateRowBuffer())
                                    // Copy attribute values from the source to the target
                                    foreach (ArcGIS.Core.Data.Field sourceField in sourceFeatureClass.GetDefinition().GetFields())
                                        string fieldName = sourceField.Name;
                                        if (featureClass.GetDefinition().GetFields().Any(f => f.Name == fieldName))
                                            // Check if the field is writable
                                            if (featureClass.GetDefinition().GetFields().First(f => f.Name == fieldName).IsEditable)
                                                // Set attribute value in the target row buffer
                                                targetRowBuffer[fieldName] = sourceRow[fieldName];
                                            else
                                                // Handle non-writable field (e.g., log a message or skip)
                                                Console.WriteLine($"Field '{fieldName}' is not writable.");
                                    // Insert the new row into the target feature class
                                    insertCursor.Insert(targetRowBuffer);
                    // Flush the insert cursor to commit the changes
                    insertCursor.Flush();
}, featureClass);
I am using the above code copy from source feature class to target but it is not inserting all fields. Can you help with inserting all fields from source to SDE?
Aashis
by Esri Contributor
ArcGIS works with specific database management systems (DBMS) data types. Depending on the DBMS  type, a field's precision, scale, or geometry type (Geometry vs ST_Geometry) may change. Some DBMSs don't support the field types that exist in another DBMS.
 File and mobile geodatabase data types are the same as ArcGIS data types. For DBMS, ArcGIS data types map to database data types and can differ depending on the DBMS. Here is the mapping table of supported field data types for each DBMS. Users should be responsible for creating a properly mapped schema before migrating data.
With this mapping information, could you please tell us which field values/types are not copied from one environment to another?
SumitMishra_016
        continue;
