Retrieve Scale from All Maps
1141
10-28-2021 06:18 PM
TheBobScript
I am able to get a list of all maps in a project (Project.Current.GetItems<MapProjectItem>()) and display a number of properties, like name, layers, spatial reference, etc.  One thing I cannot seem to access is the current scale for each of these maps (MapProjectItem).
I would like to retrieve the scale for all of my maps in my project.  I know you can retrieve the scale for an active map (MapView.Active.Camera.Scale), but how do I get the scale for a map that is not active?  Can I retrieve the scale from each map without making it the active map in my project?
KirkKuykendall1
I don't see scale but to get the extent, this works:
protected override async void OnClick()
    //Saving the project is needed to assure the
    // map definitions are in sync with the view extents
    await Project.Current.SaveAsync();
    await QueuedTask.Run(() =>
        foreach (var mapdef in Project.Current.Items
        .OfType<MapProjectItem>()
        .Select(itm => itm.GetMap().GetDefinition()))
            Trace.WriteLine(mapdef.DefaultExtent.ToJson());
TheBobScript
Hi Kirk - Thanks for taking the time to reply.  I'll take a look at what you have shared and see if that helps with what I'm after.
