Remove graphics layer doesn't work
825
10-14-2021 03:12 PM
LeLuong
New Contributor III
All,
I'm trying to remove the graphics layer on map.  Codes did go through
 graphicsLayer.RemoveElements(graphicsLayer.GetSelectedElements());
but nothing happened.  My graphics layer is still there.  Am I missing something?
 protected async override void OnClick()
      //Get the graphics layer
      var graphicsLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        await QueuedTask.Run(() =>
          //Remove existing graphicsLayer
          if (graphicsLayer != null)
Thanks!
2 Solutions
GKmieliauskas
Your code removes selected elements of graphics layer. To remove graphics layer you need to remove map layer using QueuedTask.Run like this :
MapView.Active.Map.RemoveLayer(graphicsLayer);
LeLuong
New Contributor III
Thank you very much @GKmieliauskas .  I actually wanted to remove all elements.  I should use
graphicsLayer.RemoveElements(graphicsLayer.GetElements()); instead of
GKmieliauskas
LeLuong
New Contributor III
