Remove basemap service credit from Map layout
1825
09-11-2023 01:40 PM
HelenZhou
Hello,
I have created a map layout with Basemap.TopographicVector as the basemap. The credit of this basemap server covers quite some space on the lower right corner of the layout. I am wondering how to remove the credit?
Thanks so much
Wolf
by Esri Regular Contributor
If you don't want the service layer credits to show up on your map you can place them anywhere on your layout as a text element.  You can do this via the ArcGIS Pro UI or programmatically:
String slcText = "<dyn type='layout' name='SLCs' property='serviceLayerCredits'/>";
GraphicElement slcTxtElm = ElementFactory.Instance.CreateTextGraphicElement(layout, TextType.RectangleParagraph, slcEnv, arial8reg, slcText);
Wolf
HelenZhou
Thank you @Wolf - it works.
