Regression Test does not shutdown application properly
825
07-11-2023 08:10 AM
ole1986
I have migrated the regression test example from our previous Arcgis Pro 2.9 to 3.1
After testing I noticed that the whole Test procedure keeps running (even all tests are already completed).
Reason for this is line 6 of the below snipped in `TestEnvironment.cs` and causes our DevOps operations to become freezed
public static void StopApplication()
            try
                if (Application != null)
                    Application.Shutdown();
            catch (Exception e)
                //do not re-throw the exception here.
                Debug.Print("Application.Shutdown threw an exception that was ignored. message: {0}", e.Message);
I workaround this by gracefully kill the testhost.exe process as following
            try
                    var proc = Process.GetCurrentProcess();
                    proc.CloseMainWindow();
                    // below might hang after all tests succeeded
                    //Application.Shutdown();
            catch (Exception e)
Luckily the results are not affected after killing the process that way.
Also, there are no project edits or pending save operations.
Regards
